Multifunction DAQ
USB-6001 Ext Trig Using PFI0
Using the USB-6001 Multifunction DAQ:
Using the NIDAQmx C function, DAQmxReadAnalogF64, I get a status code error -200414 which means InvalidSmpClkSrc. I specify the Source as PFI0 in the DAQmxCfgSampClkTiming function. I have tried variations such as /Dev1/PFI0 but still get the error. Using a Null Source string and the internal sample clock, the device works normally and I get the analog data.
Can anybody let me know what is wrong?
(4,291 Views)
Accepted by Jim1162
The USB-600x devices do not support external sample clocks.
On the USB-6001, PFI 0 and 1 may be used for counting digital edges or as start trigger signals for AO and AI. (See the PFI 0 and PFI 1 topic in the NI USB-6001/6002/6003 User Guide), not as an external sample clock signal.
(4,266 Views)
I am going to upgrade to the USB-6210 so I can use PFI0 as a trigger for the sample clock.
(4,227 Views)
