Multifunction DAQ
USB-6000 Driver
I firstly installed successfully DAQmx 20.5 on a PC running Windows 10. When I connect my USB-6000 DAQ, it is successfully recognised by Windows and MAX.
Then I tried same installation on a PC running Windows 7 SP1. I have installed DAQmx 20.1 (latest version supporting Windows 7 SP1). Unfortunately when I connect my USB-6000 DAQ module, Windows Device manager doesn't install any driver successfully and MAX doesn't recognise it.
Do I have to install a separate device driver for this old version of windows ?
Can you help me ?
Pierre
(2,454 Views)
OK. I could finally install the USB-6000 driver on Windows 7. I had to downgrade to DAQmx 19.0.0 and use offline installer.
(2,374 Views)
