‎06-30-2008 07:05 AM
‎06-30-2008
09:05 AM
- last edited on
‎11-10-2025
03:25 PM
by
Content Cleaner
‎06-30-2008 09:40 AM
Dennis,
That makes sense since I am using multiplexing mode in PCI-6071E. If ghosting is an issue with subsequent channels why not just skip a channel for each analog input. The reading for the channel that is wired up and being acquired is completely accurate so apparently the ghosting does not have a detrimental effect on the first channel.
This makes me wonder if this is happening also in my analog output module 1163. I have two channels wired up subsequent to one another to control a gas flow controller.
-Scott
‎07-01-2008 09:18 AM - edited ‎07-01-2008 09:26 AM
‎07-02-2008 06:54 AM
‎07-07-2008 10:32 AM
‎07-07-2008 11:50 AM
Paul,
When you turn on Switch B you do not see a response in Channel 14 at all. The two switches are wired in parallel with Switch A connected to Channel 13 and Switch B connected to Channel 14. Why would I see no response with Switch B in Labview 5.1.1? Is that channel not configured correctly and if not how would I go about that?
-Scott
‎07-07-2008 03:53 PM
