The sampling rate is not as what I set
 In my DAQmx, I set the sampling rate at 20 kHZ (Picture 1 ), but the data I acquired was sampled at 10Hz rate (Picture 2).
Who can help me? Thank you.
My VI is attached.
Message 1 of 8
(4,673 Views)
The Rate is in Samples per Channel per Second.  So since you have 2 channels, your sample rate for each channel is cut in half, resulting in a 10kHz sample rate.
GCentral
Message 2 of 8
(4,642 Views)
HI, the sampling rate is 10Hz instead of 10KHz
Message 3 of 8
(4,631 Views)
Just guessing:
You sample 5k samples with 20kS/s , but your indexing of the array seems to be wrong, so you pic (and mix) both channels instead of 2 times 5k samples you save 2 times 2 samples.
5k with 20kS/s each 1/4s * 2   ..... do you have 10Hz or 8Hz samplerate in your  data??
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(4,604 Views)
I think you are right. You said my indexing of the array seems to be wrong. How chould I change the indexing of the array.
Thank you!
Message 5 of 8
(4,593 Views)
Reading the help of the index array function would be a starting point 😉
Henrik
LV since v3.1
Message 6 of 8
(4,580 Views)
Jaseon,
I think the issue is that you are getting columns (samples) of data back when you index your array and not rows (channels) like what you want. I believe this is what Henrik is mentioning. Change the VI as shown in the picture below:
Wire the 0 and 1 constants into the Row inputs (not the column) of the Index Array VI. You should also right-click on the Build Array function and make sure that Concatenate Inputs is disabled.
Aaron W.
CLA, CTA and CPI
Message 7 of 8
(4,569 Views)
Any discussion of sample rate rate with a DBL array is meaningless. There is no timing associated with the samples.
Message 8 of 8
(4,560 Views)
