Multifunction DAQ
The programming cannot detect any requires driver
Good day to all..
I have create a simple programming using Labview 7.1 to read a force from the signal conditioning unit using strain gauge sensor. I used DAQcard-700. Unfortunately,  DAQ Assistant Express VI said that there is no requires driver. So, I would like to know how to make it works. Thank you.
(2,903 Views)
I have a bad new, the DAQ Assistant will not work with the DAQ card-700.
It is a driver issue. The DA Card-700 is only supported with the driver NI-DAQ version 6.9.3 that is not supported by LabVIEW 7 and later on indicated in the following link.
NI-DAQ for Windows Support for Different LabVIEW Versions
Best Regard
Nick_CH
(2,892 Views)
