06-11-2010 01:44 PM
I was running nidaqmx 8.7 on winxp ok, then I installed a brand new PCIe-6363. It required an upgraded nidaqmx driver, so when I installed version 9.0 which came with the card, it installed, but the Measurement and Automation explorer Test Panel feature does not work (no errors, just nothing happens). When I try and run Test Panels from the command prompt, I get "MFC90.dll not found" type of errors.
I have uninstalled/re-installed NI software, xp service pack 3, and visual studio 2008 runtime libraries to no avail. Copying MFC90.dll and a few others does not seem to work due to different versions of these *90.dll files.....HELP.
Any clues?
06-14-2010 02:04 PM
Howdy Johnny!
It could be possible that the disk you installed from was corrupted. Try downloading DAQmx 9.1.1 from the web and installing from that.
09-13-2010 06:34 AM
Hi, johnny9999999
Have you solved your problem yet? I ran into the same case today and found a solution. You may try the following steps
1) go to C:\WINDOWS\system32
2) rename the file named "nidmfpan.exe.manifest" to something like "nidmfpan.exe.manifest.back"
3) try open testpanel on MAX or type in run as "nidmfpan.exe /devid:dev1"
Osamu
National Instruments Japan
09-13-2010 01:11 PM
Thanks, I will try that...other fixes had not worked still to this day...
03-29-2011 07:35 AM
Renaming the .manifest file worked for me.
I even copied the mfc90*.dll files that where stored in a folder under C:\winnt\winsxs\... to C:\winnt\system32 but that didn't work.
Not sure what went wrong with the installation of NIDAQmx 9.2.3.
Thanks again for the tip.
Ralf
