Terminate DAQ voltage generation?
Hi all, I'm new to LabView and these forums I hope to learn and contribute much in the near future.
I created a simple VI that takes Desired Temperature and Current Temperature as inputs, compares them, and then applies a voltage based on the comparison ( CurTemp < Desired  --> voltage out) but I'm having trouble understanding why when Current Temp = Desired Temp the DAQ continues to generate a voltage. This occurs even after the VI is stopped completely.  VI is attached and thanks for any suggestions!
Sleepar
Tech Info:
NI 6009 DAQ
Win 7 x64
LabView 2012 Student Edition
(3,415 Views)
Accepted by Sleepar
An analog output will hold the last value written until he device is reset.  You need to make sure to write out a 0V when you don't want an output and when closing down your program.
(3,412 Views)
Crossrulz,
Thanks a ton my friend, I expected the solution to be so simple it makes you want to kick yourself for not having thought of it; and of course it was!
Sleepar
(3,397 Views)
