Although I don't see why it wouldn't work, you wouldn't have the same amount of accuracy. Using the Cable Fault detection vi's as a place to begin you can use DAQmx for all the hardware calls. Simply generate a square wave on your counter and continuously read in on an
analog channel.
Good Luck
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
