Multifunction DAQ
TDR Measurement using PCI-6251
Hello ... i am interested in using my current setup (PCI-6251 and BNC 2110 connector block) to make a time domain reflectometer (TDR). I read the tutorial 'How Do I Perform Time Domain Reflectometry (TDR) Analysis Using NI Products?' but do not have money to purchase new products.
I am interested in obtaining characteristic impedance for small transmission lines. Does anyone have any experience building a TDR in software using a standard multifunction board? I would be very interested in some help with this. Thanks.
(3,092 Views)
Although I don't see why it wouldn't work, you wouldn't have the same amount of accuracy.  Using the Cable Fault detection vi's as a place to begin you can use DAQmx for all the hardware calls.  Simply generate a square wave on your counter and continuously read in on an analog channel.
Good Luck
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(3,079 Views)
Thanks for the reply ... I have in fact worked on it, and it is just a question of resolution. Thanks!
(3,072 Views)
The PCI-6251 is a rqther slow (1.25 Ms/sec sampling rate) unit.
For TDR you need (pulse rise time)*(velocity of light) << (length of the transmission line being investigated). This will not be the case unless you are working with VERY long cables.
(3,070 Views)
