Synchronize both counters on USB6218
I need to use both counters on my USB6218 to generate 2 square wave signals, with one signal being 180 degrees out of phase with the other. i.e. when one signal is in the high state the other must be in the low state. I've attached my attempt to do this but it gives error -10503 (The specified resource is reserved. The operation could not be completed as specified) after I start the second counter (using DAQmx Start Task).
Any ideas?
Andrew
Message 1 of 8
(3,941 Views)
Andrew,
Your attachment is missing.
Message 2 of 8
(3,936 Views)
Message 3 of 8
(3,915 Views)
Here is my attempt at combine the two counter outputs into the same channel. It gives the same error as the original vi.
Message 4 of 8
(3,910 Views)
Andrew,
Can you post your vi in 8.2?
Message 5 of 8
(3,897 Views)
I don't know how to convert the file to a 7.2 format.
Message 6 of 8
(3,895 Views)
I thought there is a way in LV 8.5 to save a vi to version LV 8.2   Unfortunately I'm not running 8.5 yet.
Message 7 of 8
(3,892 Views)
I've worked out how to do it, both files are attached in the zip file.
Message 8 of 8
(3,883 Views)
