Multifunction DAQ
String to DAQMX Physical Channel
@Ameyawcules wrote:
I am trying to do the same thing but when I connect the index array to the Physical Channel the line breaks and I get the error "You have connected two terminals of different types". Also from the phot you can see that the Physical channel VI has no output termnial where I can feed it into the create vi. How do I also change that?
It could be a case that the array constant is not of DAQmx physical channel and hence the broken wire.
Santhosh
Soliton Technologies
Message 11 of 11
(523 Views)
