Multifunction DAQ
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Status Code: -50352
I have been chasing a problem with a piece of equipment of almost a year.  Please provide meaningful help.
I am a test equipment vender.  I have a shell program that I have been using for over 10 years in other equipment without any problem. My shell is created in VB.net 2005 using NI measurement Studio 8.1.  The machine in question has:
DAQmx 9.4
9178 rack with:
   9201
   open
   9425
   9425
   open
   9472
   9472
   9472
The application will write to the DO (9472) several times a second.
It appears to be a memory leak.  I have tried many things to alleviate this problem; the computer will only run for about 2 days and then it crashes as the memory usage climbs.  This is the only message showing up in my log files:
NI Platform Services:  The requested memory could not be allocated.
Task Name: _unnamedTask<0>
Status Code: -50352
With in one second this message is written to the file 635 times.
this is the main code that writes to the hardware
Try
            digitalWriteTask.WaitUntilDone()
            writer.WriteMultiSamplePort(True, DOWrite)
Catch exception As DaqException
            WriteToTesterLogFile(exception.Message, LogTypes.Software, True)
End Try
writer = Nothing
Thank you for your help,
Jeff
Messaggio 1 di 2
3.305Visualizzazioni
Hi Jeff,
This sounds like it may be CAR #327313: "Host PCs that use CompactDAQ can crash after long periods of continuous use", which was fixed in NI-DAQmx 9.5. In NI-DAQmx 9.4, uncommitting a CompactDAQ task leaks 20 bytes of kernel memory.
If you can't upgrade to the latest version of NI-DAQmx at this time, you may be able to work around the problem by calling digitalWriteTask.Control(TaskAction.Commit) once and reusing the same task over and over again.
Brad
Brad Keryan
NI R&D
Messaggio 2 di 2
3.295Visualizzazioni
