Multifunction DAQ
Spec for cold junction sensor on CB-68T?
What is the specification (i.e. manufacturer/pn) for the cold junction sensor (CH0) on CB-68T? It is labeled as RT1.
Jonathan
(3,792 Views)
Hi Jonathan,
Take a look at page 14 of this document. Let me know if you need additional specifications for the CJC sensor.
Michael P
(3,788 Views)
Michael, I downloaded that document yesterday. While that tells me the relationship between temperature and resistance, it doesn't tell me how to order a device that will behave the same as part RT1 on the CB-68T. What I am trying to do is to replace the CB-68T with a custom termination board. I would like the board to have the same interface as the CB-68T - thus my interest in learning the manufacturer and model number of part RT1. Jonathan
(3,779 Views)
Hi Jonathan,
That information is not made available to customers.
Michael P
(3,769 Views)
That's enough to get you hot under the collar, it's not like it is a proprietary partmad smiley
Since NI won't assist maybe I can. based on the data in the PDF file link, it looks like a C curve thermistor. Here is one that may be close.
http://www.rhopointcomponents.com/product_detail.asp?mid=F&st1=Temperature+Sensors+and+Compensators&...
This google link may help out some more, I used the folling text to search on it:
"5000" + "thermistor" + "c curve"
http://www.google.com/search?hl=en&q=%225000%22+%2B+%22thermistor%22+%2B+%22c+curve%22
You may want to look at it to see if there is any text on it, search Google with that text.
Good Luck
AK2DM
(3,765 Views)
