Multifunction DAQ
Configuring two digitizers in master/slave
Posted in the Labview forum, but the lack of responses led me to believe that I had chosen the wrong forum, so I'm cross-posting here.
Running WinXP Home and Labview 7.0 Express.
I'm considering attempting a master/slave configuration with a 5112 and a 5122 that I have on the same motherboard so I can have four channels running simultaneously. Is this worth pursuing? Specifically, I'm wondering if there will be any sort of compromise in performance because of the different specs of the two models.
Also, is there anything special I need to do hardware-wise to get this running?
Thanks in advance for your help.
(3,069 Views)
http://forums.ni.com/ni/board/message?board.id=150&message.id=1072&jump=true#M1072
(3,057 Views)
