11-18-2008 04:41 PM
11-19-2008 11:46 AM
11-19-2008 12:04 PM
11-19-2008 03:02 PM - edited 11-19-2008 03:02 PM
Hey Csossi,
The USB-6221 supports hardware timed DIO and will be able to control this servo. Also, if you use a counter to control the servo, the USB-6501 will work as well. If you just have one servo to control, the 6501 is going to be the cheapest option; if you have multiple servos to control, the 6221 might be a better choice.
11-20-2008 02:03 PM
11-24-2008 07:55 PM
11-25-2008 05:51 PM
Hey Csossi,
Earlier I recommended using the 6501's counter to interface with your servo. Unfortunately, this will not work due to the fact that we only have access to the counter source input line; we need access to the counter output line. Sorry for this mistake. For best results, I would still recommend the 6221 because it has hardware timed digital I/O. We could also use the 6210's counter lines, but the hardware timed DIO of the 6221 is a much easier route.
Since both of our products are rather expensive, as an alternative I would recommend using a serial to Servo PWM controller. These can cost less than 50 dollars and can control multiple servos. We can use basic serial read/write commands in LabVIEW to set the motor position. This requires no NI DAQ cards and uses the PC's serial port. Our devices are more than capable of controlling your servos, but a hard-wired servo controller will get the same job done for less money.
