Multifunction DAQ
Simultaneous analog inputs
Hello everybody,
I'm trying to analye two signals simultaneous with the anaol inputs dev1/ai0 and dev1/ai1 but I can't do it.
I'm using PCI-6034E.
In attachement my Vi(without .lib)
Can anybody help me please.
Best regards.
(3,381 Views)
I guess you didn't quite understand my explanation on how to use multiple channels in a single task from your earlier post.Smiley Sad
You have Dev1/ai1 in the first assistant, Dev1/ai1 twice in the second assistant and Dev1/ai0 in the third assistant. In English there is a 'Show Details" button that displays this information. You want to have one DAQ Assistant with both channels. In the assistant wizard, when you are asked to pick the channels, select ai0 and then hold <Ctrl> or <Shift> to select ai1. Just like it says at the bottom of the physical channel window.
(3,375 Views)
Thanks dennis,
it works now well.
(3,357 Views)
