01-30-2007 06:25 AM
01-30-2007 08:25 AM
I guess you didn't quite understand my explanation on how to use multiple channels in a single task from your earlier post.![]()
You have Dev1/ai1 in the first assistant, Dev1/ai1 twice in the second assistant and Dev1/ai0 in the third assistant. In English there is a 'Show Details" button that displays this information. You want to have one DAQ Assistant with both channels. In the assistant wizard, when you are asked to pick the channels, select ai0 and then hold <Ctrl> or <Shift> to select ai1. Just like it says at the bottom of the physical channel window.
01-31-2007 11:23 AM
Thanks dennis,
it works now well.
