Simultaneous AO and AI with NI USB 6001/MATLAB DAQ toolbox
I am very new to data acquisition and bought an NI USB 6001 to start learning. Since I can get MATLAB free via my university, I'm using the Matlab data acquisition toolbox as the DAQ software.
My problem is that I get the following error message when I try to generate an AO signal (voltage for an LED) and measure an AI signal (voltage from a 9V battery) simultaneously.
Warning: This change caused queued output data to be flushed.  Use queueOutputData to queue data before starting the object.
Hardware does not support the specified connection. Check the device's user manual for valid device routes and pin-outs.
However measuring the AI or generating the AO each by themselves works perfectly fine.
My Matlab script looks like this:
daq.getDevices;
s=daq.createSession('ni');
s.Rate = 1000;
s.DurationInSeconds = 10;
addAnalogInputChannel(s,'Dev1','ai0','Voltage');
addAnalogOutputChannel(s,'Dev1','ao0','Voltage');
aoVoltage=1.8+0.1*sin(linspace(0,2*pi,10000))';
queueOutputData(s,aoVoltage);
s
startBackground(s);
Note that adding the AI and AO channels to the session also works, however I get mentioned error when the session starts. Is this a limitation of my DAQ hardware (I don't see something like that mentioned in the manual) or do I have to alter the script?
The connected pins for the LED are AO0(+) and AO GND(-).
The connected pins for the battery are AI0(+) and AI4(-). (The problem is still there if I use ground reference for the AI)
Message 1 of 10
(10,593 Views)
For Matlab questions, you should post to the Mathworks forum.
LabVIEW is also free for students of you change your mind and want support from NI.
Message 2 of 10
(10,528 Views)
Accepted by himmellaeufer
6001 can't do simultaneous tasks.  Pretty standard limitation of the lower-end hardware.... just don't have the computational resources on the board to handle that stuff.  Even the 621x boards only have limited multitasking capability.
Can either step up to a higher-end DAQ ($$$$) or buy a 2nd low-end one and synchronize tasks in software (timing's not as accurate).  I've done both approaches, which one is "best" really depends on the application.... if low cost or high performance is a priority.
Message 3 of 10
(10,517 Views)
Thanks! What would I be looking for in the product description/manual to find out if the hardware is capable of multitasking? Is this the same as multichannel or does this only refer to acqusition of the same channel type, e.g. all AO? I already tried measuring multiple AO inputs and this worked. So does this mean that I can only measure/ generate multiple signals of the same type? So generating a DO and measuring a DI simultaneously or generating a DO and measuring a AI simultaneously is not possible either?
Message 4 of 10
(10,497 Views)
I have same question. Where is the simultaneous ability?
Message 5 of 10
(7,697 Views)
From Mathworks:
"Tim, this does not error in MATLAB R2017b.
However NI USB-6001, NI USB-6002, NI USB-6003 do not have internal trigger signals, so the analog input and output channels will not have a hardware-synchronized start with the default configuration.
So, to have synchronized analog input and analog output channels with these device models you need to use external triggering with an external PFI terminal and addTriggerConnection."
Source: https://uk.mathworks.com/matlabcentral/answers/309786-unable-to-get-ni-usb-6002-to-generate-and-read...
Message 6 of 10
(7,300 Views)
Can i read 2 Analog Inputs simultaneously? Or does the board not support it... ????
Any help would be really appreciated!
Message 7 of 10
(4,401 Views)
Simultaneously in software - yes, possible, just include both channels in the same task
Santhosh
Soliton Technologies
Message 8 of 10
(4,385 Views)
Hello, thank you for the response, I was wondering if there was a python way of doing it? I do not have any experience with LabVIEW OR matlab. Can you help? Thank you!
Message 9 of 10
(4,378 Views)
Of course, you can use the Python DAQmx drivers and there are a few examples too.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8o0SAC
Santhosh
Message 10 of 10
(4,338 Views)
