Multifunction DAQ
Simulate arbitrary waveform analog output
Can the Simulate Arbitrary Waveform Express VI be used to output analog signals to physical channels on analog output systems such as the NI 9263? I am trying to use the arbitrary waveform generator VI to output a signal used to drive magnetic coils.
(3,933 Views)
Accepted by Zach_Phys_Research
Why don't you just try it and see what happens?  As far as I know, it should work.
(3,925 Views)
