Multifunction DAQ
Setting Up 6111
Hi, I have a PCI-6111 that I am measuring a voltage signal with (output of ignition coil).
I am curious as to how this should be physically connected and setup on my BNC-2110 & in MAX.
I currently have the BNC-2110 set to FS, and MAX automatically sets the measurement to psuedodifferential.  My physical connect I have the voltage going to the center pin of the BNC connector on the BNC-2110.  I am kind of curious if this setup makes sense and wondering how the ground should be wired exactly.
Thanks in advance!
Ryan
Ryan
LV 7.1
(3,264 Views)
Hi esa,
You shouldn't have a problem connecting the BNC-2110 to the PCI-6111.  I checked with the S Series Help file under Connectors & Accessories and it appears to be a supported combination.
Just keep in mind that you will not be able to read anything on analog input channels 2-7 because the PCI-6111 has only 2 analog input lines.
(3,255 Views)
Measure voltage out of an IGNITION COIL- I hope you intend to use some sort of voltage reduction 🙂
 What is the peak output of the coil versus max allowable input voltage of the card?
(3,254 Views)
Thanks for the replies.
You are both correct, this is not the first unit I have made; however I was having unexpected results with this unit and was trying to recall exactly how I had setup the last unit.  (if you are curious the peak voltage I expect to see is around 27,000 volts)
I found the problem yesterday; the voltage reduction unit I am using was leaking voltage to ground, creating very strange, fluctuating results.
Thanks for the help!
Message Edited by esa_paranoid on 07-27-2005 06:29 AM
Ryan
LV 7.1
(3,247 Views)
