Greetings Dave,
To save Traditional NI-DAQ virtual channels:
Open MAX and go to Tools »Traditional NI-DAQ Configuration»Save Configuration As.
Save your current configuration to a file and close MAX.
Note: When you launch MAX, it searches for the name of the last active configuration file and uses that file as the new data source. Any changes you make in MAX are automatically saved to the file. Saving the configuration file also sets the new file as the active configuration file. So, if you do not want to use your saved configuration file the next time you open MAX, you can either change the active configuration file the next time you open MAX or simply rename the file you just saved. If you choose the second option, MAX will not find the last active
configuration file and will create a new configuration file.
To use saved Traditional NI-DAQ virtual channels:
Open MAX and go to Tools»Traditional NI-DAQ Configuration »Set Active Configuration.
Browse to and select the saved file.
Note: When you set the active configuration to a saved file, remember that MAX will use that file as its new source until you use another configuration file or change the file name.
Hope this helps,
Anuj D.
Applications Engineer
