09-23-2020 08:04 AM
I have a PXIe-6363 and a SCB-68A.
I want to use RSE terminal configuration so that I can utilize all the AI pins separately.
I have soldered resistors from positive channels in B and D pads to AI ground for signal conditioning.
My input is coming from AO0 and I use a common ground for AO ground and AI ground (keep in mind there is a resistor between each AI pin and the AI ground).
The problem is when I try to measure the voltage across any resistors some form of noise appears.
The noise intensity reduces when I increase the input voltage.
The noise disappears completely when I measure the voltage across a capacitor.
I have fully grounded the unit but still have some noise.
When I perform FFT on the recorded signal it shows a peak at 60Hz, but it doesn't make any sense.
everything is grounded.
Please if you have any idea help me.
I would appreciate it.
10-30-2020 11:21 PM
This issue was resolved using a faraday cage
