Multifunction DAQ
SCB-68 with multiple programs
We have 1 SCB-68 DAQ and we want to run two LabVIEW programs that use the same SCB-68 simultaneously
Each program has to send & receive signals via the SCB-68.
If we design the programs to use different channels on the SCB-68, will there be any other conflicts?
Thank you kindly,
(3,608 Views)
The SCB-68 is a dumb terminal block and not a DAQ card so you can't do acquire anything with just that.
If you have an actual DAQ card and you want to use different channels of the same resource such as analog in or analog out, then you cannot have multiple programs access the card. You can't have a single program create separate tasks. The reason is that there is a single clock and the driver will not allow separate tasks. You could have a single program that scans all of the necessary channels.
(3,600 Views)
The NI SCB-68 is a shielded I/O connector block for interfacing I/O signals to plug-in data acquisition (DAQ) devices with 68-pin connectors.
What DAQ device do you actually have and will you want to run these 2 programs at the same time?
Dennis beat me to it. Smiley Very Happy
Message Edited by GovBob on 02-01-2010 06:28 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,597 Views)
