I'm using PCI-6071E With SC-2345 on LabVIEW 7. I want to use DAQmx but the SC-2345 not in the Accessorys list. Is there any way to use SCC-AI01 with DAQmx? thanks Elad Shehori
Right click on "NI-DAQmx Devices" in MAX and then select Create New NI-DAQmx Device...>>NI-DAQmx SCC Connector Block>>SC-2035. After that the configuration window will open and you can configure your SCC box.
Hi Luca, First Thanks for your quick replay. I've download the new NIDAQ driver (7.2) and it's include SC-2345. So Thanks again for your support and I'm happy that I've helped you to 😉 Elad
