SC-2345+DAQmx
I'm using PCI-6071E With SC-2345 on LabVIEW 7.
I want to use DAQmx but the SC-2345 not in the Accessorys list.
Is there any way to use SCC-AI01 with DAQmx?
thanks
Elad Shehori
(3,246 Views)
Hi Elad
Right click on "NI-DAQmx Devices" in MAX and then select Create New NI-DAQmx Device...>>NI-DAQmx SCC Connector Block>>SC-2035. After that the configuration window will open and you can configure your SCC box.
Hope this helps.
Luca
Luca
(3,245 Views)
Hi Elad,
I've seen a little mistake. You've to select SC-2345 and not SC-2035, which doesn't exist, by the way! 😉
Luca
Luca
(3,245 Views)
Hi Luca,
First Thanks for your quick replay.
I've download the new NIDAQ driver (7.2) and it's include SC-2345.
So Thanks again for your support and I'm happy that I've helped you to 😉
Elad
(3,245 Views)
