‎11-13-2006 02:37 PM
‎11-14-2006 09:31 PM
‎11-15-2006 09:06 AM
Thanks Brian,
Thomas help me to fix this.
Jey
‎11-16-2006 05:44 PM
‎11-17-2006 09:20 AM
Here are the coversation between Thomas and me regarding above issue.
Hi Jey,
navigate in LV to Tools - Options - WebServer: Browser Access and change the settings to your point of view.
If you want to give every IP (every client) full access, add a "*" (without the apostrophes), check that the option "Allow Viewing and Controlling" is enabled and afterwards submit your settings with the add button.
Close the dialog with the ok button, restart LV and try it again...
BR,
ThSa
Hope this helps,
ThSa
that is absolutely right, but there is a simple workaround.
You have to build the executable with menubar enabled, but implement with VI server the functionality to disable the menubar solve the problem.
BR,
ThSa
Message Edited by ThSa on 11-14-2006 09:11 PM
