Relay control
Hi All,
Was looking for some advice on driving a relay using Digital output from the NI USB 6002.
As I understand from the manual/spec this is an open collector output. Am I correct in thinking each output can only sink 4mA?
My understanding of the open collector output is that I can use an external voltage source ie. 12V connected through an external pull up resistor and sink to ground through the output. However I have to respect the sink current of the open collector output, but this seems low at 4mA.
(4,294 Views)
You have to respect the transistor that is being used to drive that signal low.  In this case, it is a really small transistor that is rated for 5V and 4mA.
You might want to look at using a USB-6525, which is designed to handle the industrial signal levels.
(4,275 Views)
I'm specifically trying to avoid that solution in this application, thanks for the recommendation though.
If I were to add a relay driver such as the ULN2003 or an opto-isloator maybe I could operate relays this way.
Have you any advice or thoughts on this method?
(4,270 Views)
Accepted by hughes265
I have not gone those routes before.  But looking at the data sheet for the ULN2003, it should work just fine for you.
(4,265 Views)
Thanks for your help.
I have also found a lot now on the forums if searching for NI usb and ULN6003.
This is indeed the way forward and the solution I require.
(4,261 Views)
I solved with this TOSHIBA Photocoupler 6N139.
Greetings Luca.
(3,738 Views)
