Multifunction DAQ
Re-Imaging of NI CDAQ-9135
 I have NI CDAQ-9135 device with its own windows embedded CPU and also with multiple chassis connector  and i want to change it to linux real time like from windows image to linux image . now the question is :- is it possible?if yes, how can i do it?
(224 Views)
Can I Change the Operating System of My cDAQ-913X?
Unfortunately, changing the operating system on the embedded CompactDAQ controller is not a supported process.
In addition to having to purchase a real-time license in the case of going from Windows to Linux RT, there are also the following concerns:
  1. The Serial Number of the cDAQ will correspond to the original OS. If the chassis needs to be factory-reset, it will revert back to the original OS.
  2. If the device should fail during the installation of the alternate OS, NI will not be able to offer support in recovering the device.
  3. NI suggests migrating to the CompactRIO platform in case you need a C series chassis with Linux RT.
https://tmesystems.net/
(191 Views)
