Multifunction DAQ
NI-PXIE-6368_AO/AI_Dual_Tone_Generation and Capture_(Inter modulation Distortion)
Hi Team,
Dual tone of 20Khz and 25Khz wave form is generated at 1MSPS sampling rate with NI-PXIE_6368_AO channel and the same is captured with NI_PXIE_6368_AI_channel at 1MSPS sampling rate below are spectrum of the captured wave.
Input Wave Form:
Actual Spectrum:
Zoomed in spectrum:
while studying the spectrum it seems that every 5Khz (5,10,15,20,etc...) spurs are occurring repeatedly.
Could you please suggest how to avoid this spurs while measuring IMD?
Sagar
(232 Views)
@sagar7077bishwas wrote:
Hi Team,
Input Wave Form:
Actual Spectrum:
Zoomed in spectrum:
Sagar
How are you ensuring a continuous generation? regenerate from memory?
How are the two-tone signal generated, from file or from formula?
Santhosh
Soliton Technologies
(221 Views)
And if you try 20kHz and 26kHz ?
But my first guess also would be in the same direction of santhosh: Generation : Do you repeat a block of 2.5 ms length ?
Another point:
You want that the output and the input sample are delayed by half a sample. (allow the output to settle)
In Software: use different edges of the sampleclock for AO and AI (or different sampleclock delays  if supported)
Hardware : build a 500ns delay line ... about 100m RG58 😄
Greetings from Germany
Henrik
LV since v3.1
(174 Views)
