Multifunction DAQ
Range for NI 9205 using MATLAB
The NI 9205 comes with the 5 different input voltage ranges, how does one change the range from MATLAB?
After changing the range does the 16 bit resolution scale to this new range? for ex for -1 to 1V, step size will be (2/(2^16))?
Also the sample rate is given as 250kS/s does that mean for each second, I get 250k different 16bit values for all the inputs? if not what does the sample rate actually mean?
Message 1 of 1
(1,137 Views)
