Multifunction DAQ
Can I duplicate test test panel in Labview?
Is there a simple way to duplicate the functionality of the NI MAX test panel inside labview? I am using a USB 6343 as a control device for some other hardware. I am debugging and changing individual inputs/outputs on the fly, so the test panel has really been a good tool. Unfortunately, it is a bit cumbersome as I have to match up each line to the device under test. If I had the same controls in labview I could rename and rearrange them so they make sense in relation to the device under test instead of the USB6343 device.
(1,357 Views)
Definitely you can replicate it in LabVIEW since those Test Panels also use the same drivers that you can access with LabVIEW, but its SOURCE CODE IS NOT OPEN FOR PUBLIC, you've to start from scratch or use the shipping examples.
Santhosh
Soliton Technologies
(1,320 Views)
