Multifunction DAQ
RSE grayed
    What could be the reason for RSE channel configuration to be GRAYED.
    I am using NI-DAQPad 6015 and Laptop (could Laptop be the reason)
    It is not avaliable in Labview (if I select error is generated) and in MAX test panels (ONLY NRSE and DIfferential)
(3,101 Views)
RSE mode is not supported by your device, hence it is grayed out
this link mentions so
http://digital.ni.com/public.nsf/allkb/ECA86B184EF3B88086256C240067109C
Since these are "Basic" Multifunction devices, there are some features that are not supported in order to reduce the cost to the end user. In the table below, an "X" means that the feature is supported; a "----" means the feature is NOT supported.
Note: The DAQPad-6015 must have the Mass Termination option to support SCC.
~~~~~~~~~~~~~~~~~ NI 6013/6014/6015 E Series
SCC Support X X
SCXI Support ---- X
RTSI Bus ---- X
RDA Support X X
External Metal Shield ---- X
NRSE and Diff Modes X X
RSE Mode ---- X
Temperature Sensor
(for calibration)
---- X
Regards
Dev
(3,090 Views)
