Multifunction DAQ
RPM with usb 6000 and digital Input
Hello I want to measure the Frequency of a signal (0-5V) in a USB 6000.
Since it does not do frequenzy readings I have to write the code by myselfe.
I want to use the digital input and measure the time between two edges.
So far so good. but my calculated frequenzy jitters around the correct mean. I have differences of 33 Herz up and down.
Frequenzy to read 200 Hz. So 5 ms between two phases. Signal TTL (0-5)
Here a codeexample of my while loop.
(4,352 Views)
You are probably having normal jitter when using software timed acquisition. A five msec variation is actually quite good with just using the Windows timer. Why don't you use an analog acquisition with multiple samples and use the built-in analysis routine for frequency measurement?
(4,345 Views)
That's what I figured.
There is no way to use the internal clock of the usb 6000?
I did that and was not happy with the measurement time.
Thanks for the reply
(4,342 Views)
You only have an internal clock for analog input. Upgrade your hardware to something that has an actual frequency counter if you are unhappy with the 6000. It's a poor choice for what you want to do.
(4,337 Views)
Thanks. I will do that.
Recommendations? 2 counters would be preferable.
(4,328 Views)
