Python command with USB-6009
I try to use USB-6009 in Python 2.6 environment at Win7 64bit system and I'm facing  issues with following command.
The following issues I see following error command
  1. dll = windll.LoadLibrary("C:\\Windows\\System32\\nicaiu.dll")
    ....#command with return value!=0
    error_str=c_char_p('')
    b_size=c_uint(2048)
    ret_a=dll.DAQmxGetExtendedErrorInfo(error_str,b_size)
    Following the last command the python  I get the attached error message
    Am I doing something wrong?
Thank you for help,
(4,715 Views)
Accepted by Katerina
Hi Katerina
You could try replacing 'c_char_p' with 'create_string_buffer.' According to the Python reference library , "you should be careful, however, not to pass them (edit: c_char_p) to functions expecting pointers to mutable memory. If you need mutable memory blocks, ctypes has a create_string_buffer() function which creates these in various ways."
from ctypes import *
dll = windll.LoadLibrary("c:\\windows\\system32\\nicaiu.dll")
error_str = create_string_buffer(2048) # try this instead of c_char_p("")
b_size=c_uint(2048)
task_handle = c_uint(0)
error = dll.DAQmxStartTask(task_handle) #this will result in an error
try:
    dll.DAQmxGetExtendedErrorInfo(error_str, b_size)
    print error_str.value
except:
    print "oops"
Let me know if this helps.
Sunil
(4,699 Views)
It works, Thanks a lot.
(4,670 Views)
