Multifunction DAQ
Pulse input from flow meter?
I have a basic multifunction PCI 6013 card. I would like to read in the pulse input from a flow meter (around 20 pulses/sec) and convert it to volumetric flow rate. I've scoured the example vi's and forums to no avail. There are counters on the board so I believe this is possible. I'd only need to read data for a short duration because only average flow rate is needed. Thanks for any help.
(2,872 Views)
You were close.
Look for the examples on gated pulse counting.
Try "count time easy.VI" (check your board spec's to amke sure your example fits your hardware).
Ben
(2,872 Views)
