Attaching the diagnostics result file:
Using the newest released DAQ diagnostics program, running with DAQmx 8.1
An additional info: I'm using the BNC2110 connector box, which might also have an upper-limit cut-off
Hongbo
12_12_2005 21_09_59
Results saved to: C:\Dokumente und Einstellungen\User\Desktop\Hongbo\Diagnostic Results.txt
Selected Device: Dev1
Device Type: PCI-6221
Serial Number: 11D09A2
Device Support: (PASS)
NI-DAQmx Version: 8.1 (PASS)
Device Reset: (PASS)
The device was last self-calibrated on: 12_12_2005 19_33_33
Running Calibration ... (PASS)
-------------------- Testing Counters... --------------------
Testing CTR Buffered Pulse Generation... (PASS)
Testing CTR Single Pulse Generation... (PASS)
-------------------- Testing Analog Input... --------------------
Testing AI Ground Reference... (PASS)
Testing AI Voltage Reference... (PASS)
Testing AI Finite Sample Clock... (PASS)
Testing AI Finite Sample Clock Frequency... (PASS)
-------------------- Testing Analog Output... --------------------
Testing AO Finite Sample Clock... (PASS)
Testing AO Finite Sample Clock Frequency... (PASS)
Testing AO Single Point... (PASS)
Testing AO Accuracy... (PASS)
-------------------- Testing Digital IO... --------------------
Testing DIO Lines... (PASS)
Testing DIO Ports... (PASS)
----- DIAGNOSTIC TEST COMPLETE -----
