Pretrigger Samples minimum 2 for DAQmx Reference Trigger ?
DAQmx Trigger with Reference Analog Edge seems to require a minimum value of 2 for pretrigger samples per channel.
If correct, I do not see that mentioned in LabVIEW version 2017 Help nor DAQmx version 19.0
Steve
(2,180 Views)
I can't directly confirm the minimum=2 you seem to observe, but have seen several other areas around DAQmx where 2 is the minimum legal value.  So it sounds plausible that might be a real limit even if not clearly documented.
Do you get an error when you ask for 1 or does the task silently coerce you to 2?
-Kevin P
(2,166 Views)
Other situations of requiring a minimum value of 2 that I have experienced are related to clock ticks usage, for example with counter output pulse generation.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6i5SAC&l=en-US
I wouldn't think that pretrigger samples would require clock tick usage in this manner or at least think the DAQmx driver could accept a value of 0 and then adjust or configure the hardware and possibly the acquired data to accommodate values less than 2.
The task does not coerce to 2.
Steve
(2,151 Views)
