Multifunction DAQ
Power supply for USB-6363
Unfortunatelly, our collegues have lost the NI power supply for USB-6363 DAQ. We need a raplacement a soon as possible. Is it possible to use as a power supply laboratory DC power source GPS-74303 (GOOD WILL INSTRUMENT) with propper connection? In the file attached you can find specefications of this device.
(5,427 Views)
Look on page 18 of the requirements document and you will find the requirements for the input power.  Also, under pricing on the Product Page, you will see "Universal Power Supply with Mini-Combicon Connector - 781513-01", which would be your replacement power supply.
(5,423 Views)
Could you specify the polarity of power supply input?
(5,390 Views)
Hi Kupecz,
In the power supply input on your USB-6363, you should have a pin labeled "C" on the left and "V" on the right. The "C" stands for common (-) and the "V" stands for voltage (+). Does this answer your polarity question?
Rita Prather
Software Product Manager
rita.prather@ni.com
(5,353 Views)
