 Kupecz
			Kupecz
			02-19-2016 10:23 AM
Unfortunatelly, our collegues have lost the NI power supply for USB-6363 DAQ. We need a raplacement a soon as possible. Is it possible to use as a power supply laboratory DC power source GPS-74303 (GOOD WILL INSTRUMENT) with propper connection? In the file attached you can find specefications of this device.
 crossrulz
			crossrulz
		02-19-2016
		10:39 AM
 - last edited on
		05-06-2024
		10:19 AM
 by
		 Content Cleaner
			Content Cleaner
Look on page 18 of the requirements document and you will find the requirements for the input power. Also, under pricing on the Product Page, you will see "Universal Power Supply with Mini-Combicon Connector - 781513-01", which would be your replacement power supply.
02-22-2016 04:48 AM
Could you specify the polarity of power supply input?
02-23-2016 12:48 PM
Hi Kupecz,
In the power supply input on your USB-6363, you should have a pin labeled "C" on the left and "V" on the right. The "C" stands for common (-) and the "V" stands for voltage (+). Does this answer your polarity question?
