10-10-2007 02:00 AM - edited 10-10-2007 02:00 AM
Message Edité par gbugnard le 10-10-2007 02:04 AM
10-11-2007 09:39 AM
10-11-2007 09:51 AM
10-11-2007 11:21 AM
yes that could work if the Odd/Even would be a TTL signal
but it isn't. As I see in the datasheet is the high level 0.8 and referenced to
the TTL specification is the range from -0.3 to 0.8 a low value. Also you must
trigger on a falling edge because a frame starts with it.
Picture and frames are the same but I explicit mention it like this because it’s the same as with a continues and singel sample measurement. Continues measurement is much faster than single measurement with the same rate, because the device must not send and receive for each sample some commands. The same is with a camera. A video with 30 frames per second is like a continue measurement. You send one command to set the parameters and one to start the video acquisition and than you get the video stream.
You must try if your camera is so fast also by single pictures.
Stefan
10-11-2007 02:40 PM
10-12-2007 08:51 AM
10-14-2007 10:13 AM
10-15-2007 02:31 AM
