Multifunction DAQ
Pci-lv error load
When I choose pci-lv.dll file in call library function , appears error. On another computer all works good. Adlink drivers was installed. Whats the problem might be ?
(1,977 Views)
I have a similar problem... did you find out what the proble was?
(1,790 Views)
Your DLL needs to be the same version as LabView, if your LabView is 32-bit the DLL needs to be too.
(522 Views)
