07-11-2005 05:40 PM
07-12-2005 09:20 AM
07-12-2005 09:40 AM
07-12-2005 03:02 PM
04-24-2007 12:10 PM
Analog output does not support a stop trigger, and there isn’t an easy way to achieve this functionality using hardware timing. The easiest workaround would be to use a digital start trigger to begin generation and software timing to stop generation.
On the other hand, there is an example that ships with LabVIEW that demonstrates analog generation using a pause trigger. If you had a hardware switch that acted as an ON/OFF switch for the analog generation, you could use this to begin and end generation. In addition to this, you would be able to restart the analog generation if you then turned the switch on again. The example can be found by browsing the example finder to Hardware Input and Output >> DAQmx >> Analog Generation >> Cont Gen Voltage Wfm-Int Clk-Pause Trigger.vi.
Ed W.
