07-31-2023 02:37 AM
Hello, I have a chassis with a pxie-8301 card (with no onboard controller).
The PXIe-1084 is in a bay and must be powered on when the mains voltage appears without pressing the button on the front panel.
I can't find how to do it online! With onbord controller it's ok but without ???
thank you for the Help!
07-31-2023 08:03 AM
From Power-Up Options for PXIe Chassis From PC With MXI Express
The PXIe-8301 does not support a remote power-up option. However, it also has no requirement for the order in which the chassis vs computer is powered up. An alternative is to generally leave the chassis on and plug/unplug the Thunderbolt connection before powering on the computer. NI does not support hot-plugging the Thunderbolt connection.
If your PXIe-1084 has the Timing & Synchronization Upgrade, you can enable the remote inhibit to power it on automatically. See Part 2 of Remotely Powering on an NI PXI Chassis
08-01-2023 01:39 AM
Hello, I have a lot of problems with this pxi!
With the thunderbolt everything is ok (except the problem of starting).
On the pc of the machine I have a pcie 8361 (8360 in the chassis). Impossible to start the chassis before the pc otherwise the pc doesn't boot. The pxi is start too late so it is not recognized!
I saw a lot of identical subject I did a lot of manipulation, I just have to update the bios of my motherboard (I did not update the chassis .. .) .... but impossible to find this one (industrial pc)....
08-02-2023 08:24 AM
A little feedback after finding the solution:
chassis PXIe-1084
pxie 8360 and 8361 board
My chassis crashed the boot of the pc, impossible to start the pc with the chassis on.
I had to update the bios of my motherboard.
I had to update the firmware of the 2 cards.
The chassis detected under daqmx, I always had the problem of having to start it by hand.
I applied the ni procedure: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIEECA4&l=fr-FR
I find it unacceptable that you have to go through an executable on the command line to change this parameter!
i hope it will be usefull !
04-18-2024 06:29 AM
In theory you might be right. But in practice the cards may get new IDs when restarting Windows and then any Aliases used are unusable.
I truly regret letting my customer talk me into the Thunderbolt solution. It is just so shaky and unreliable.
It work for a lab environment, where you have engineers that know how to reconfigure once in a while. But for a production environment I would never in a million years recommend the solution.
11-18-2024 03:43 AM
Hello!
It is the same issue in my case as well.
You said 'I had to update the bios of my motherboard.'
What did you have to update on your bios?
Balazs
11-20-2024 06:47 AM
hello, sorry for the answer a bit late !
I have update the firmware of the motherboard of the pc connected to the PXI chassis.
Update with the *.bin finded on the official MSI web site.
