Multifunction DAQ
PXI Trigger with DAQmxCfgDigEdgeStartTrig fails
Alright here is another question from the novice:
First what I want to do:
1) Get Timestamps from a PXI-6682
2) Synchronize those time stamps with Analog inputs
Now here is what I did so far:
NI-Sync:
1) Create a clock that generate 1 rising edge per second on NISYNC_VAL_PXITRIG0
2) Link that clock to create timestamps on rising edges
NI-Daqmx:
1) Create Task
2) Create a channel
3) Link channel start trigger to "PXITrign" <--fails...weird that I shouldn't use NISYNC_VAL_PXITRIG0 =
"PXI_Trig0"
Now I need to do this because I want to have a timestamp exactly when I start fetching samples.....because my preliminary tests created abuffer overflow because my timestamp was never available (so every time I got samples I would wait 1 second before getting them)
What am I doing wrong?
(3,633 Views)
It sounds like to me you are looking to get time stamps from the 6682 of all of the analog input samples.  In my opinion  a good starting point might be the following community example that combines a DAQ task with an NI-Sync timestamping task.
http://decibel.ni.com/content/docs/DOC-3362
I found the link above from going to NI.com/community and searching for: DAQmx time stamp
Let me know if you have any other questions..
Charley Dahan
Global Account Manager
(3,613 Views)
Accepted by topic author Sebastien Dupere
First of all thank you for your reply.
Yes I did stumble on this piece of information, although sadly I do not use LabView but C++...
Furthermore,
I solved my compiling issue by using NISYNC_VAL_PXITRIG0  afterall (Seems the name was a bit misexplained in the Daqmx library
But now I got more issues popping up, but those are on other threads.
So I guess I will close this one and let my other threads give me more answers 🙂
Thank you though,
Seb
(3,604 Views)
