09-15-2006 03:47 PM
09-18-2006 02:05 PM
09-18-2006 02:25 PM
Hi Calvin-
Yes, you need to protect against both cases (overvoltage and overcurrent). The voltage protection is only effective up to +-25V (device powered on). If you exceed that overvoltage protection level or exceed the overcurrent spec during an overvoltage condition (i.e. anything above the working voltage) then device damage may result. You should ensure that you neither exceed the overvoltage protection maximum nor drive more current than spec'd for the "overpower" condition.
Hopefully this helps-
09-18-2006 02:29 PM
Okay, I still don't know if during the device off condition, rather or not +-15V is considered an "OverVoltage Condition.
09-18-2006 02:31 PM
Hi Calvin-
Yes, even when the device is powered off you should be careful to avoid overcurrent conditions. FYI, any input above the working voltage spec is considered an overvoltage condition.
09-18-2006 02:37 PM
Okay, Thanks for the answer.
