Multifunction DAQ
PXI 4072 error, code -88705
Hi all
I have several PXI1042 systems, in one of them a 4072  card has an error, when I make "selftest" in MAX, it show me an -88705 error, message is mean that card is absent or has an error. In windows system device manager, this card seems correct.
Then I insert another card4072 in this chassis, it works, software environment is MAX3.1, DAQmx 7.3.1, DMM 2.3.1.
Finally under another software environment which is consist of "MAX 4.0,DAQmx 8.0 "I install the broken card to a PXI 1044 platform, windows find a unknow PCI device, and automatically installer can't find suitable diver, device manager show me a yellow "?" then I replace it with another 4070 card, windows verify the model correctly.
In my opinion this card has a hardware error maybe. Is there anyway to fix it? Only ship to NI?
*The best Chinese farmer*
(3,323 Views)
Additional, I have checked NI sevice in "msconfig" and ensure they are all running, on the same chassis other cards such as 6259 are working correctly, so I think software environment has no problem.
What do you think about this??
(3,322 Views)
Any solution?
(3,306 Views)
