Multifunction DAQ
How to make the analog output determined after stopping the task
This is part of the program
// build up a rect waveform
memset(m_Data,0,m_nSampleNumber*sizeof(double));
  for(int i=0;i<m_PulseDutyFactor;i++)
   m_Data[i]=m_nMagnitude;
 ///  build up the task
  DAQmxErrChk(DAQmxCreateTask("",&m_TaskHandle));
  DAQmxErrChk(DAQmxCreateAOVoltageChan(m_TaskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL));
  DAQmxErrChk(DAQmxCfgSampClkTiming(m_TaskHandle,"",m_nFreq*1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,m_nSampleNumber));
  long written;
  DAQmxErrChk(DAQmxWriteAnalogF64(m_TaskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,m_Data,&written,NULL));
  // start the task
  DAQmxErrChk(DAQmxStartTask(m_TaskHandle));
/// change the output waveform (change the pulse duty factor )
if( m_TaskHandle!=0 ) {
  double mag=m_nMagnitude;
  m_PulseDutyFactor=pdf;
  long written;
  res=DAQmxStopTask(m_TaskHandle);
// restart the task
  res=DAQmxWriteAnalogF64(m_TaskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,m_Data,&written,NULL);
  res=DAQmxStartTask(m_TaskHandle);
When I call "DAQmxStopTask", the task stop, but the analog output is random, sometimes it is zero and sometimes it is full-voltage (m_nMagnitude).
The question is:
Could I make the output on some determined value eg. full-voltage (m_nMagnitude)?
Or there some better sollution for me to change the continuous output waveform without a break (DAQmxStopTask) ?
(3,008 Views)
Is it possible or impossible?
Please help.
(2,998 Views)
