03-03-2014 05:03 PM
Is it possible to use the PCI-DIO-32HS with Windows 7? If yes, can you direct me to the correct driver to install?
Thank you.
03-04-2014
09:47 AM
- last edited on
02-27-2026
11:14 AM
by
Content Cleaner
Hi aaron.cramer
There is a Traditional DAQ driver for Windows 7. The driver does not work for 64-bit operating systems.
This link describes the limitations of the driver and links to the download: https://www.ni.com/en/support/documentation/compatibility/22/traditional-ni-daq--legacy--windows-vis...
03-28-2014 03:28 PM
Board works under DAQmx, 64 bit Win7
