PCI-6024E
I am using PCI-6024E for data acquisition. I hope it working properly. But it is failing on selftest when I use MAX. How can I fix this?
Jey
(3,902 Views)
Hi Jey,
are you using traditional DAQ for Data acquisition?
If u are, then just reset the device after end of acq,  by using Device reset.vi
I recall having this problem while switching from traditional DAQ to DAQ mx and solving it by resetting the daq device as explained
let me know if it works
regards
Dev
(3,892 Views)
Thanks Dev,
                   It works. I have other question. I can see PCI-6024E  both under traditional DAQ and DAQ mx. It passes on the seltest under DAQ mx not under traditional DAQ. Is that ok to remove/delete device under traditional DAQ? What is the difference between these two?
I am new to this area.
Thanks for your help.
Jey
(3,886 Views)
Thanks Dev,
              I collect the necessary info.
Jey
(3,865 Views)
 Jey glad i could be of help to u!
Hope you have been able to locate all necssary info
To put in simple words, Traditional DAQ is the older version of device drivers for NI hardware and now its a legacy device driver, Now NI developed DAQ mx a more easier and advanced device driver( well, at times i have seen a few instances where traditional daq still seems to be a more suitable option!)
these two links should give u more info
https://www.ni.com/en/support/documentation/supplemental/06/answers-to-frequently-asked-questions-ab...
https://www.ni.com/en/support/documentation/supplemental/06/transition-from-traditional-ni-daq--lega...
regards
Dev
(3,853 Views)
Thanks Dev,
                   I really appreciate that.
Jey
(3,840 Views)
