PCB Mountable Connector (NI-9202)
Hi NI,
Could you direct me to a PCB mountable version of the 36-Pos Spring Terminal on the NI-9202?
https://www.ni.com/en-us/support/model.ni-9974.html
We need to directly connect to the module via a custom PCB board and cannot use the spring terminals.
(2,678 Views)
Roman Sandoval,
It does not appear that we sell any PCB mountable versions of cDAQ connectors.
Would it be possible to use a pcb mountable third party terminal block, and wire that terminal block to the NI-9202 via the spring terminals?
VanCamp
(2,646 Views)
Preferably not because we want to create a PCB that connects directly to this module(s), which would then connect to our fixturing.  We want to be able to mitigate the risk of poor assembly due to wiring.  Is there a similar part aside of the spring terminal that can directly interface with the NI 9202 module?  Or is there a mating connector that can directly interface to this spring terminal that can be soldered?
-Roman
(2,641 Views)
